tonype
- New Jersey
Home connected to a WWII army surplus generator (Willy's engine). Cable from the generator is connector to the top "on" postion; power grid connected to the lower "on" position. This way, the generator is isolated from the public grid.
Switch is rated for 100-amps; however, main breaker and SEC (outside) are 200-amps (and was represented by Seller as 200-amps). However, this switch is the weak link and I am calling this a 100-amp system.
If this switch is replaced, can this be swapped out with a 200-amp rated switch, or will a whole host of updated code requirements have to be met? My feeling is the latter will be required at a big expense.
