zbang
- Roughly 5346 miles from Earls Court
I'm looking for info about an old (probably pre-2000) E-mon D-mon KWH meter. The label gives the model as "208100" (4-wire 120/208/240v 100 amp) and a copyright of 1989. Inside, the display board only has Reset and Test Display buttons, not the 4-button set in the current Class 2000 meters. Also, there are two 8-pin modular connectors on the main board labeled "IMON J1" and "DIRECT J3".
I'd like to put this to use and get a pulse output or even Modbus, but I don't have a clue where to connect. Anyone?
