Old homes arc-fault protected
gimpyfac
We are under the 2002 code, one of our Villages is going to have a grant to fix up homes, my question is if they put more outlets in the bed rooms, does that require them to make the bedroom arc-fault protected? I think the grant is threw the state or Hud. Most of the homes are over70 years old.
Re: Old homes arc-fault protected
It has been my expierence, When you change any part of an electrical system, I have been required to bring that portion up to standard code. If you were just changing out an outlet, then I would say that the current wiring would be fine.
Anyone disagree????
ryan_618
Hello Gimpy. Depending on how much "fixing up" you are doing, you may be required to install smoke detedctors throughout the building, one of the VERY few retro-active aspects of the IRC. If that is the case, you will also need them to be AFCI protected. As far as the receptacles go, I would agree with iceman. Hope this helps.
[ August 21, 2003, 07:54 PM: Message edited by: ryan_618 ]
