malachi constant
- Minneapolis
A family member called me with a head-scratcher. They live in an older (~1920s) house, been there over five years. New panel was put in maybe 20 years ago, some of the house has been rewired - all that is properly grounded. However there are still portions of the house that have no grounding. House is one story plus attic bedroom and basement.
Over the summer he switched cable/internet/phone providers. Worked OK for a couple months, but the last month it has been terrible. (I believe he said cable is OK, but phone and internet are bad, but maybe I got cable and phone mixed up.) Got a technician out there this week who said it was the grounding in the building that was messing it up. I am hearing all this second hand, but sounded like the technician got a little nip while working outside the house, and another one inside, put his meter on the line, saw some voltage, and walked away telling the homeowner he needed to have an electrician look at it. Before he left he did try, from both interior and exterior, running a ground wire from the coax sheath to the water main. Didn't seem to do anything.
They had zero issues with the previous cable/internet/phone provider. They have had zero issues with the house electrical system, with the lone exception of their electric blanket having to be replaced at least once each winter. (!?!) I had him check that the panel was bonded to the water main, it was, with bonding across the meter, so I assume the service panel is properly grounded and that the problem is downstream.
He's willing to call in an electrician to do some troubleshooting or updating, but is wondering what kind of investigation he can first do on his own. I suggested shutting off breakers and turning them on one-by-one...but unfortunately don't know what to tell him he should be metering as he turns each of them on. Sometimes the internet works fine, so it's hard to use that as indicator.
Seems plausible enough to me that faulty grounding would be the culprit, though I'm surprised bonding the coax didn't do anything, and it is suspicious that the old provider had no issues at all. It's an annual contract, and while not impossible to get out of it switching back to the old provider isn't his first option.
Wish I could come up with a better troubleshooting scheme. I can teach him a number of tricks for rewiring old homes with minimal damage. I'm looking more for ways to isolate the problem, so he can do this in pieces over the next few months and in the meantime not have to forego having an internet/phone/cable connection. Any suggestions? Thoughts on costs if he does hire an electrician?
Thanks!
Thanks!
