Re: old house
Originally posted by roberto41106:
im about to rewire a older home . i was wondering is it necessary to update it to code or could i just rewire what is there and it would pass inspection. and also i usually run wires through the rafters but i see a lot of newer homes that do not have that and they are just running everywhere. is that against code?
Well, everything there (assuming it was to code when it was installed) is still technically speaking "to code". The NEC isn't retroactive.
An early 1900's knob and tube and fuse box installation could, in theory, pass an inspection today if everything was still in decent condition and met the level of code in force when it was originally installed.
There may be safety issues related to old wire decay and wear that should be addressed, as well as the usability aspects of keeping old 2-prong ungrounded circuits in service.
Usually there's going to be cost factors as well as safety. Some old stuff can be kept in service and still be safe, or made safe with some relatively minor and inexpensive changes and be safe and usable for another 70 years. Other old stuff may just be not worth saving.
If its additions of new circuits to add capacity those would need to be to current code, even though other unchanged parts might not.
Unless you've got an unlimited wallet, this sort of thing is usually taken on a case, by case basis to get the most bang for the buck without compromising safety.
Realistically, passing an inspection shouldn't be your primary goal on a rewire job - "passing" really isn't all that hard to accomplish. What you want is to wind up with a well designed system that you can live with and will meet your needs today and any reasonable expectations into the forseable future. A system that "passed an inspection" might be frustrating and unusable even though its "safe".
