Old keyless
Never saw anything like that before. Are there screws inside the lamp socket? Anything down from the top?
-Hal
With your experience it must be pretty rare if you have not seen it. I was going to say with your seniority...but didn't
The socket appears to be a Crouse-Hinds "Norbitt" condulet fitting listed below as "Receptacle without Shade Holder Groove":
It's attached to what looks like a type "K" condulet:
Two screws inside of the lamp socket fitting attach it to a porcelain base that's mounted inside the condulet:
I believe you need to remove the screws from inside the socket
Yes that was it thanks, they were obviously hot and neutral but went into another ceramic piece that had a screw that mounted to box
So I was able to carefully remove lampholder without damaging, and then accidentally drop on concrete floor and shatter
Im sorry, but that’s funny.
It’s a happened to me also, and it’s still funny...
