Anybody seen this type of setup before? An old main fused disconnect switch rated 300A acting as a main in this electrical room, 240/120 high delta, westinghouse type box probably around 30 years old at least. What they have done overtime is continuously tap the same lugs into smaller disconnect fused switches that fed other panels..... The cables on load side and the next disconnect is not rated for 300A, so they are unprotected. Also, i see no grounding cable and the building did not have a ground rod. The owner wants to add more circuits to this building. I see a few code issues, old equipment, missing lugs, missing grounding. My opinion to provide a main enclosed breaker outside with a ground rod and replace this main old fused disconnect with a main panel and re-feed all the existing panels. Is there other cheaper solution to do this?
Thank you
Thank you
