wireperson
- Florida
any ideas how to make this MD more compliant to code?
on grounding?.I have to feed 4 split systems from this MD .
Did you think about installing a distribution panel.wireperson said:any ideas how to make this MD more compliant to code?
wireperson said:I sugested that to owner. the usual, they want the hvac working for now, and he's going to upgrade sometime soon.
this is a better visual of what all this looks like.my concern is the phase balance , they are installing single phase split systems
there's gotta be some sticks and cardboard wedged in there.
I opened a can and found a stick - it fell out - but when I went to close it I found out the hard way what it was there for - when the kearny blew through the cover.peter d said:there's gotta be some sticks and cardboard wedged in there.![]()
Do the same for the line side - look closely there are two - of different sizes taped together in each....acrwc10 said:Change the lugs on the out put side of the fuse to multi hole lugs.
