Coreyd1@optonline.net
I went on a service call and found that when I plugged in my receptacle tester is showed open ground. The home owner changed all his receptcles to 3 prong receptacles that were install in a metallic box with old "original" 2c romex with no grounding conductor. The conductors are Aluminum. What is the proper or common practice to fix the installation. Install 2 prong receptacles or a GFCI Breaker? If someone could please advise or point me in the right direction in the code book. Thanks in advance.
