I disagree with this. Through the decade of the 1960s we lived in the Early Atomic Age. Central Air Conditioning, Heat Pumps, Electric Ranges, Electric Water Heaters, Electric Clothes Dryers, Electric Furnaces, Disposals, Dishwashers, Submersible Wells, etc. all existed and were provided for as the builder designed the Dwelling. The Power Company transformers installed then are, in my opinion, still the same size they were when the subdivision was electrified in the Sixties, with an occasional exception. The length of the PoCo secondary conductors and the dwelling service lateral or drop has not "shortened" nor has it been replaced with heavier gauges in most of the cases. The PoCo philosophy that if their circuit doesn't burn down, it's safe to continue, is still firmly entrenched, in my opinion.
Let me say that again. The subdivision wired by the PoCo during the decade of the Sixties (the decade that reduced EGCs were installed in Dwelling Branch Circuits) has, in my opinion, largely the same sized transformers today.
The transformers aren't moving closer to the house and the branch circuit impedance (think wire gauge) isn't decreasing because the #14 (or #12) is somehow gaining Copper.
The Sixties end-of-small-gauge-branch-circuit fault current of 70 to 200 Amps is still what is available, today, in most cases, in my opinion.
