- Massachusetts
Over the years I have worked on a few different older motors that used resister banks switched via rotary drum switches or contactors to control the motor speed control.
And while I have worked with them and made some basic repairs I really do not understand how they work.
How does diverting the voltage through the resistors control the motor speed? I thought cycles controlled the speed of an AC motor. :huh:
How is this voltage produced, the resistors were not directly tied into the line, they came from the armature so the motor is a generator at the same time?
Assuming a correctly sized motor could I run it continuously at a slow speed with out damage or can you just step through the speeds to get to full speed?
While running at a reduced speed will it hold a specific RPM with varying loads?
