short circuit faulted
- Columbia SC
Is it still permissible by NEC to use THW single conductor on insulator knobs from a home to a detached garage to repair an existing old installation?
Not sure if it ever was.
Why...because, I wasn’t sure if it ever was.Why do you say that? It's rated
....NEC references would be greatly appreciated.
Thank you
Steve
Next question is what is conductor size, length of span, did it meet overhead clearance requirements, is the insulation sunlight resistant?Ask and you will receive, Knock and the door will be opened into you...
Thanks
