wc86
- Massachusetts
- Electrician
Could anyone give me a rough idea of how old a house would be to expect knob and tube, bx, and romex(without any updates)? Im in Massachusetts if that makes a difference.
This is very cool! Thanks!Here is a brief timeline:
1985-2024 romex is just like today NM-B 90C insulation.
pre 1985 - 1970 is the more modern wiring era, however that pre 1985 romex can be worse than knob and tube, as it could not take the heat from the old 100W incandescent. Aluminum wiring/busbar from this era had issues. Also breaker panels such as FPE were known to be defective and lost their UL listing.
1962 - 1968 Grounded romex started out but we used the Canadian sized equipment grounds, not all outlets were required to be grounded, it was phased in.
1962 - 1928/26 , I think the bulk of todays old wiring is this era, 100% ungrounded romex, during the war years the quality of rubber went down, BX and knob and tube were still widely used. Plugs and fixtures were standardized but non-grounding types.
1901- 1928/26 You'd see open wiring on insulators, BX, concealed Knob and tube, wooden wiremolding, exposed busbar, RMC, open switches, light fixtures were not required to have have boxes. However overcurrent protection was much more restrictive 6 - 10 amp fuses were common. Switch polarity, system voltage and outlet types were all over the place not as standard as today. 50hz, 40hz, 25hz DC and odd combinations of two phase were used in some places. Gas'o'leers Combination gas / electric lights were not uncommon.
Prior to 1901's definitely either concealed knob and tube, or open wiring on insulators, no bx or greenfield (flex) before this date, fixtures were marked in candle power not watts. Anything you find from this era send me a PM.
30 amp, pennies or, for the affluent, dimes, is mostly what I've seen6-10 amp fuses? Haven't seen that, regional perhaps?
Prior to the 1923 NEC the maximum fuse allowed on a lighting circuit was 10 amps.6-10 amp fuses? Haven't seen that, regional perhaps?
