I have a few holes cut for the slater old work plastic round boxes.
They are listed for 20lbs. (see luminaries support must be rated for 50lb)
Started reading about to see if they where listed for ceiling..... couldn't find any thing.
A link brought me to an older (2010) post here........ (which is closed).......I see through that post and article 314.27 (A) the requirements...........
Are there any exceptions for ceiling use (50 or 20 lb rated boxes) for something that's lighter than a feather like a smoke detector..
Also the post mentions how the box is supported from the sheet rock so it's a no go (for luminaries) What if your ceiling was constructed of plywood........or in my current case, wood lathe/plaster???
Thank you
I must mention too,the cats meow..............finding a beam to install a pancake box.......alls beautiful, then I see the pancakes I was going to use (raco 4x1/2) have a cu " of 6.0...........there goes a 3 wire smoke (unless you guys can find
me an exception like the ground in a 3 wire nm doesn't count in conductor fill of a box when installing pancake boxes for smoke detectors)
Same thing for the raco "fan"cake box for a fan/light.........6.5 cu"...................dooped !!
Thank you
