bjp_ne_elec
- Southern NH
Because I'm new to old work - vast experience on new installs. both commercial and residential - I'm seeing how you guys would handle this situation.
Two gang box in living room - old romex with undersized ground on all but one of four romex coming in to box. One is feed, one is three way, one is feeding off to other parts of circuit - fourth romex is going back down to basement, as it was intended to be switch leg to lamp post (finally to be installed by me). This fourth romex has no ground wire at all - and this is not good - as this is one intended to run to new lamp post.
This "fourth romex" comes in to bottom of box, in to metal two gang box, and my desire it to get it replaced with a 14/3 - so I can bring the feed up in a new circuit (so I have EGC) and one conductor in the 14/3 would be the switched leg out to light. Now the challange - and of course the living room has paint "that's tough to match" - so the customer in no way wants me cutting in to sheet rock. Now the present romex (with new EGC) is most likely stapled, and then it also has a metal romex connector - so even if it was un-stapled, I can't use the existing to pull in a new one - as what am I going to do with the connector.
So how would you handle it? I'm sure there are going to be some neat "tricks" that I haven't considered. I've got what would be my approach, but I'll save it, and share it later. Keep in mind, my main concern is to get a EGC in the switched leg that runs out to the lamp post. It's in the UF that goes out to the post, and is already roughed in to a JB in the basement.
Thanks,
Brett
Thanks,
Brett
Thanks,
Brett
Thanks,
Brett
