Older disconnects with not enough ground connections
mopowr steve
NW Ohio
Electrical contractor
Looking at a set of plans today that show running a feeder from a spare disconnect that is already installed under a meterbase. But the ground bar only has 3 holes ....... Neutral in, Neutral out, and grounding electrode system.
So what can I do to connect equipment ground (4th wire) from sub panel. Just looking for suggestions other than changing the disconnect, if that's possible.
The disconnect is a 100 amp 1ph Pushmatic .....pisser since its in great shape and was never used since it was installed in probably the early 80's.
Think the newer style neutral bars used in today's disconnect would be compatable as far as mounting/bonding screw holes?
