alive wire
- Phoenix, AZ US
Not following product installation instructions?
What kind of hack does something like that? My journey would have slapped me with a pair of Kliens.
Always make sure the slots on trim screws are horizontal.
No there supposed to be vertical so the paint drains out.
Do you really have any control over where the screw slots end up, after you tighten to the specified torque setting? (if there is one, of course, which I doubt)
There have been discussions before on which way the screw slots should be oriented and why, and some have gone on for seemingly unlimited number of posts - but I don't want this to turn into one of those threads:blink:Do you really have any control over where the screw slots end up, after you tighten to the specified torque setting? (if there is one, of course, which I doubt)
As professionals we all know to install the middle plate last.
That will really be tricky if trying to keep the screw heads flush!Maybe one of these days they'll come out with Torx Head Screws for the cover plates and it'll end all the worry about it.
JAP>
Maybe square head instead? Clutch tip would still leave an orientation problem.
With Phillips you could have the orientation you want with less of a turn. And you could just strip out the slots to leave the screw perfectly symmetric....
But Phillips will recess nicely into an oval head screw while Torx will not.Torx orientation would be even less noticeable than phillips.
Phillips has 4 points which if out line would actually be as noticeable as a straight blade.
JAP>
Where were you when I went to school? No one taught me that.:dunce:As professionals we all know to install the middle plate last.
