MENeely
- Rural Missouri
- Retired
Lots of threads on grounding and bonding but none I found directly relate to this question: A house and a detached garage are both fed through sub panels which are fed by underground (4 wire) conductors from a single main disconnect at a meter base about 50’ away. The house sub is 200A, the garage panel is 100A. If a lightning protection ground system is to be bonded to the building service system, would it be sufficient to connect it to the ground bus in the garage sub panel? Thanks!
