We are renovating a large building with three separate services,Yesterday we shutdown service "A" and installed a temp service to feed all sub panels while we install the new switchgear .while the power was down to service "A" only one feeder had 99v from the DMM on a,b,c and neutral to ground each. Each of the wires were disconnected on each end except the neutral. I could not find out why I was getting the stray voltage.when all of the temp feeds were finished I have 3 single pole 20a breakers from two different panels that keep tripping and the surge protectors on the wall receptacles were fried. One other electrician said when one of the breakers were turned on there was an arc at the transformer.This service is a 277/480 with a y 120/208 system. Any thoughts?
