Eros
- United States
I am looking for a template or software to design detailed one line diagrams for single and three phase PV installations.
Thank you
Thank you
Thank you
I use AutoCAD LT. By subscription it's not that expensive but it's pretty sophisticated software. There is a significant learning curve.
Totally agree.I use AutoCAD LT. By subscription it's not that expensive but it's pretty sophisticated software. There is a significant learning curve.
Aurora goes a step further but it's certainly not doing it for you. Easypower, skm, and etap are good for modeling slds but not very applicable as for design software for solar.There are some basic templates for residential and small commercial systems, 240V single phase based. Once you get into 3 phase systems there really is no "template" they are all too different and require customized solutions for each site.
If you are looking for software to design the diagrams for you get in line. People have been looking for that for years. HelioScope will give you a basic single line based on your input. It's not perfect but maybe at least something to start with.
Just to add - before I got AutoCAD I tried using Microsoft Vizio to make electrical drawings. It just about drove me crazy; it works, sort of, but it's the wrong tool for the job. I also tried SketchUp with same result. In both cases I was able to make them work, but it was painful and imprecise. AutoCAD is great, IMO, especially if you have a good library of templates and blocks.
No, I haven't since I have AutoCAD and I like it.Have you tried the freeware program Draftsight by Dassault Systems?
I am sure i would prefer AUTOCAD, but not for the price. Even the $249 for the full version
I used Visio for quite a while for producing electrical drawings and I hated it (YMMV). Its lack of precision made me crazy.I use Visio Standard, $249. Fairly quick to learn. You make shapes, IE a disconnect switch, and drag into the drawing. Connect with lines. Maybe I can post a riser dwg tommorrow
But if you have to exchange electronic CAD files with others then 99.999% of the time it's going to be an AutoCAD file. And don't believe these other CAD programs that say they can read and write AutoCAD files, I have yet to find one that is 100% compatible.
The problem with CAD programs is that AutoCAD pretty much has it locked up if you have the exchange files. If you are just making drawings for yourself and to get permits you can use anything, you can even hand draft. But if you have to exchange electronic CAD files with others then 99.999% of the time it's going to be an AutoCAD file. And don't believe these other CAD programs that say they can read and write AutoCAD files, I have yet to find one that is 100% compatible. I use AutoCAD LT. Not too expensive and does everything I need.
Draftsight works with DWG's 2013 version. It also saves files in that format. I trade CAD all the time with Engineer's with no problem. It is free. Try it if you have a half hour to spare. Zero problems.
When I work with subs I have to exchange CAD files with they have to use AutoCAD or they don't get the work. It just reduces problems. I have worked with people who have older versions of AutoCAD and that's fine but not with other CAD apps.
The problem is twofold. First, Autodesk likes to tweak their DWG files every few versions of AutoCAD and since AutoCAD is by far the favored program the 3rd parties have to decompile the new format and update their software to be compatible with the latest version of DWG. The result is that if someone gives you a 2018 DWG you have to go back to them and ask for them to save the file in an older version format. Maybe the person rocking the latest version of AutoCAD doesn't like the idea of having the exchange files in the 2013 format and lose information that is saved in the later formats.
Second, AutoCAD embeds codes in the DWG files so it can tell if a file was saved from one of the 3rd party programs even if nothing was changed. When someone opens the file in AutoCAD a warning pops up saying that the file is suspect because it's been saved by a program other than AutoCAD. This can be an issue because some 3rd party programs are not all that compatible and now the person with AutoCAD has to find out if the file was mangled by a 3rd party program.
I am generally not "exchanging" files, I am producing shop drawings for various systems. Or I am acting as the designer and working with the Architect not the engineer. I just haven't run in to the problems you describe with Draftsight. I am with zbang. I will gladly explain to the customer that the Electrical Engineer that they hired refuses to export his CAD in 2013 format so that I can do my joab and it will cost xxx dollars to fix it. Frankly the way you wrote that was very aggressive and reminds me of the days when the design team would charge $50 for a CD of the plans.
