pinball
New member
- san diego, ca
Older late 40's concrete home with an addition in 1965. On the outside of the house, wires come in through drop to meter, then to a panel also mounted outside with two 60 amp main breakers. One set of wiring goes inside and feeds the original panel mounted in a closet, and the other feeds a panel installed circa 1965 through conduit mounted under the eves in a porch about 20' feet away.
The old part of the house is 2 wire. The new part is 3 wire. The "newer" panel was grounded at a water pipe, and the neutrals and grounds terminated at the same bus bar. It's been this way for 50 years. Is this correct?
