hotblueelectric
- Dallas Texas
I am building a service for a small building 2 offices 20 x 20 each.
Planning to install 3/0 service conductors in service raceway down to small gutter, then tap #3 conductors to feed 2 meter bases, then feed 2 exterior mounted 100 amp panels. One panel (a) right next to the meter base the other panel (b) about 10' away fed with emt. I am grounding panel (a) to cold water ground and also to ground rod, as well as bonding neutral to panel.
On panel (b) I am grounding to cold water ground, and running #4 thhn GEC to panel (a) ground. Also installing a ground rod at panel (b). Panel (b) will have neutral and ground isolated. Am I correct in this installation or am I missing something. This is confusing as I mainly work with residential installations. Thank you for your help.
