Open bussways
d-safe
New member
What type of guarding could/should I do to prevent accidental contact with an open bussway. The bussway is located about 6 inches off of the floor and powers a cart that moves back and forth at slow speed. It is 208v and is covered on three sides. Please let me know if you need additional info. Thanks
Sounds like the bussway was designed for installation in a restricted area (or overhead?), otherwise it would include full covers/protection. The best guard is probably a chain-link fence around the path of the cart. Does the cart have any sensors to stop if it hits something?
How large of an area is actually exposed? I see that you stated its approximately 6" from the floor but no other dimensions are listed. My first thought when I initially read it was to fabricate a sheet metal or equivelant cover that could be mounted on the exposed side. I'm not if this is feasible due to the fact that only one dimension was given.
