xguard
- Baton Rouge, LA
There are a few threads concerning fault current of an open-delta transformer. A couple people suggested adding the currents, or a portion of, from each transformer.
Below is the only source I've been able to find. It seems to suggest ignoring the smaller transformer of the two and looking at it as a single phase situation. Does anyone have any other links, references, books, etc they could suggest to backup either approach? Thanks.
http://light.dakotaelectric.com/Handbook/Pages1/Transformer Max Fault Current Values.aspx
Notes and Additional Information:
- V-Phase (Open Wye-Open Delta) services have maximum fault currents equal to or less than single-phase services with the same transformer size and voltage. Use the single-phase table and the larger of the two transformers to identify the maximum secondary fault current.
