We have a utility we are trying to interconnect with that currently is supplying three phase power to the customer with an open delta transformer. They are requiring that we upgrade the transformer configuration to a closed delta and are saying to do that they will need to run the third phase over a mile to the site. Is this correct? I thought open delta three phase power required that all three primary lines be run to the transformers whether it is open or closed. How are they providing three phase/4 wire supply to the customer from the transformer secondary if they only have two phases/hots supplying the transformer primary side?
