Family man
- Oakes, North Dakota, USA
I am having a hard time with this one. I have someone who bought a Gardner Denver air compressor from someone at an auction. It consists of a 200 amp disconnect fused at 150 amps with a sticker labeling it as 480. Then apparently went into two single phase transformers and per adventure acheived 575 volts three phase. As that is what the compressor and air dryer need. It was then fused at 80 amps before going into a line reactor and then to the compressor. The two transformers are 10 kva and have a 480/240-240/120 rating. I am unfamiliar with this open delta but I opened one and found it wired H1 to a wire that was external, H2 and H3 wire nutted together, H4 to X3 to X1 to a wire that was external, X2 to X4 to a wire that was external. I am saying external because they were in a flex. Three wires in each flex.
First off I am questioning it because it has a primary coil rating of 480 and we need 575 to operate. Secondly not sure what voltage would actually be present. Could use some input to be at peace with this one.
