I got a call from a landlord, & stopped by his rental to check out the loss of power to receptacles in a bedroom. I got a 2nd call from him before I got there & said I would call him when I found the problem. My tester showed an open neutral. I replaced a bad receptacle switch in the next room. 3rd call from the landlord. I said I replaced a switch, but not found the open neutral. I said I would call when I found it. I found the receptacle with the incoming cable & both the black ungrounded and white grounded conductors showed 120v. The problem was somewhere ahead of this room. Call #4 from the landlord, I tell him what I found. He said I did not know what I was doing, as he was an electrical engineer, & said both the black & white wires are always hot. I tried to explain in vain, then said I would put everything back in place & hung up. I ignored 2 more calls while restoring, then informed the tenant of the hazardous wiring in her baby's room. She said her landlord was working as a realtor. I will even request payment for jobs like this. What more should I do, warning notice in writing, inform Bldg. Dept.?
