Control panel has 120VAC feed. Is it a violation to use a 2-pole main disconnect and open the neutral as well as the ungrounded conductor to de-energize the panel for maintenance? The panel, of course, has an equipment ground. This issue arose because there is an ungrounded 24VDC power supply in the panel and the vendor says that the neutral should be disconnected. The panel feeds PLC I/O field devices that have no multi-circuit connections, etc.
Any input is appreciated. Thanks.
JR
JR
