openings
gimpyfac
We, have in our local code amendments,8 openings on # 14 wire,15 amp breaker and 10 openings on #12 wire, 20 amp breaker.My question is,are switches,lite fixtures, receptacles, and smoke detectors,openings? Is each box in the wall,ceiling,floor, an opening.
lrollo
Re: openings
I would think an opening would be considered a consuming outlet, such as a recepticle or a light fixture. A switch which is switching an outlet would not count as an opening but what it controls would be an opening. I also am of the opinion a smoke detector is a non-consuming outlet and may be exempted from being counted. Article 100 of the NEC should give you a definition of an outlet.
roger
Fl
Retired Electrician
Re: openings
We have a definition issue here for sure. If we look at "switches,lite fixtures, receptacles, and smoke detectors" I have never used the term "opening" to describe any one of these.
If these are specifically defined as "openings" in your local amendments, you have a legal description of the intended description and are bound by it.
They would have to be included in the amendment definition of an opening.
Roger
