ericlemmon1
- Lompoc, CA, USA
Many apartment houses, condos, cluster homes, and modular home parks are served with two phases of a 208Y/120 volt system. Since a 240-volt heating appliance such as a kitchen range, clothes dryer, or water heater will operate at 75% of rated capacity when fed 208 VAC, should it be required that outlets for such appliances be clearly marked to inform the owner of the reduced voltage? Also, since a 12kW range will require a 60 ampere branch circuit if run on 208 volts, should the NEC be updated to consider this?
