I came upon a question about how a 240V GFI would react. To ask the question, I need to give a little background. There is an adapter for motorhomes to hook up at an rv park to service a 50a motorhome from a combination of a 30a and 20a service. The adapter uses one leg from a 30a 240v service to feed one leg of a 50a 240v recept and one leg from a 20a 240v service to feed the other leg of the 50a recept. The neutrals are apparently tied together as well as the grounds. The adapter states 'will not work on gfi protected plugs.' I know it will trip a gfi, the question is when? Will it trip as soon as the adapter is plugged into the feeder or when there is a load on the recept, i.e. the motorhome?
