Your analysis/opinion on NEC 705.40 (&705.42).
You can use a single phase utility interactive inverter in a three phase system if its listing allows.
My understanding is part of UL Std. 1741 is the capability to ?Upon loss of primary source, an electric power production source" (the PV inverter) "shall be automatically disconnected??.? or by exception ?cease exporting power?.
Our jurisdictions position is that both of the above code references requires a single phase PV source when attached to a 3-phase system to cease exporting power when the primary source loses one or all phases. This would include the phase that the single phase PV inverter is not connected to.
We would appreciate your analysis and opinion
