Doesn't the NEC say somewhere in Art. 250 that, if a metallic water pipe is available then you HAVE to use it for the service neutral ground? One inspector says he..."never uses water pipe anymore"....for fear that the metal pipe will be replaced with plastic in future and.... "there goes your ground"...
Does the NEC then allow options for this ground other than the water pipe, even if it is available?
I need the exact NEC Article & par No's.
Please reply to james P. Stroke, PE, jimstroke@aol.com-thanks
