Hi. The new location for our Makerspace has 480v 3ph power available. I need to derive 240v single and 3phase power from it, as well as 120v power.
Before taking any diversity into account, we need 280 kVA of 240 3ph (includes single phase loads), 311 kVA of 120v, and 100 kVA of 480v.
A great deal of the 120v calculation is for non-continuous 120v convenience outlets.
My real question is what my transformer options are there to provide the 240 and 120v power.
I could use one transformer for 240v 1 and 3ph loads, and another for the 120v loads. A 208/120 transformer isn't much use, I don't need 208v at all. I think I could use a 240/120 split phase output on one or more of the 3 480v phases.
Is it possible to use a 3ph 480v input to create 3 240/120 volt split phase outputs?
And for that matter, can I just use one big 480 to 240/120 volt transformer with center taps on each coil? Which I believe would yield either 3ph 240v delta or 3ph 240/120v split phase power.
What is the best option in practice? Did I make any mistaken assumptions above, or miss any relevant ones?
Thank you.
Bryan
Thank you.
Bryan
