I have 2 options for grounding on a service I am doing. The panel is in the basement, the GEC going to the water pipe is separate and easy. My question is about the GEC for the ground rods:
A) Come out of the house with the GEC right near the service entrance/meter base, run through the intersystem grounding block and then down into the dirt. Run it buried in the dirt along the side of the house for about 13 feet to where it's safe to drive 2 ground rods.
or
B) Run the GEC inside of the basement along the top of the wall, then exit the basement right where the ground rods will be. But I would then have to run another conductor out near the service entrance to connect to the bonding block.
Any issues with either? Which would you prefer?
or
