Thanks, I understand that private workers are subject to OSHA regulations - while working on state and local property facilities.
I'm curious if the State or Local establishment (in states WITHOUT OSHA state approved plans) must abide to "Employer Responsibilities" found in OSHA (e.g. Employer Responsibilities copied from OSHA and pasted below), even though the state / local employees are no covered by OSHA. My interpretation is NO, the state or local government EMPLOYER does not abide by OSHA Employer Responsibilities EVEN WHEN the facility uses private contractors....However, the private contractor workers are covered by OSHA (via their employment with an OSHA abiding Employer). Would you agree?
Excerpt OSHA EMPLOYER RESPONSIBILITIES:
Employers have the responsibility to provide a safe workplace. Employers MUST provide their employees with a workplace that does not have serious hazards and follow all relevant OSHA safety and health standards. Employers must find and correct safety and health problems. OSHA further requires employers to try to eliminate or reduce hazards first by making changes in working conditions rather than just relying on masks, gloves, ear plugs or other types of personal protective equipment (PPE). Switching to safer chemicals, enclosing processes to trap harmful fumes, or using ventilation systems to clean the air are examples of effective ways to get rid of or minimize risks.
Employers MUST also:
Inform employees about hazards through training, labels, alarms, color-coded systems, chemical information sheets and other methods.
Keep accurate records of work-related injuries and illnesses.
Perform tests in the workplace, such as air sampling required by some OSHA standards.
Provide hearing exams or other medical tests required by OSHA standards.
Post OSHA citations, injury and illness data, and the OSHA poster in the workplace where workers will see them.
Notify OSHA of all work-related fatalities within 8 hours, and all work-related inpatient hospitalizations, all amputations and all losses of an eye within 24 hours. [Employers under federal OSHA's jurisdiction were required to begin reporting by Jan. 1, 2015. Establishments in a state with a state-run OSHA program should contact their state plan for the implementation date].
Not discriminate or retaliate against a worker for using their rights under the law.
