225.35 Access to Occupants. In a multiple-occupancy
building, each occupant shall have access to the occupant?s
supply disconnecting means.
Exception: In a multiple-occupancy building where electric
supply and electrical maintenance are provided by the
building management and where these are under continuous
building management supervision, the supply disconnecting
means supplying more than one occupancy shall be
permitted to be accessible to authorized management personnel
only.
225.36 Suitable for Service Equipment. The disconnecting
means specified in 225.31 shall be suitable for use as
service equipment.
Exception: For garages and outbuildings on residential
property, a snap switch or a set of 3-way or 4-way snap
switches shall be permitted as the disconnecting means.
225.37 Identification. Where a building or structure has any
combination of feeders, branch circuits, or services passing
through it or supplying it, a permanent plaque or directory
shall be installed at each feeder and branch-circuit disconnect
location denoting all other services, feeders, or branch circuits
supplying that building or structure or passing through that
building or structure and the area served by each.
Exception No. 1: A plaque or directory shall not be required
for large-capacity multibuilding industrial installations
under single management, where it is ensured that
disconnection can be accomplished by establishing and
maintaining safe switching procedures.
Exception No. 2: This identification shall not be required
for branch circuits installed from a dwelling unit to a sec-
cond building or structure.
225.38 Disconnect Construction. Disconnecting means
shall meet the requirements of 225.38(A) through (D).
property, snap switches or 3-way or 4-way snap switches shall
(A) Manually or Power Operable. The disconnecting
means shall consist of either (1) a manually operable switch or
a circuit breaker equipped with a handle or other suitable operating
means or (2) a power-operable switch or circuit
breaker, provided the switch or circuit breaker can be opened
by hand in the event of a power failure.
(B) Simultaneous Opening of Poles. Each building or structure
disconnecting means shall simultaneously disconnect all
ungrounded supply conductors that it controls from the building
or structure wiring system.
(C) Disconnection of Grounded Conductor. Where the
building or structure disconnecting means does not disconnect
the grounded conductor from the grounded conductors
in the building or structure wiring, other means shall be
provided for this purpose at the location of disconnecting
means. A terminal or bus to which all grounded conductors
can be attached by means of pressure connectors shall be
permitted for this purpose.
In a multisection switchboard, disconnects for the
grounded conductor shall be permitted to be in any section
of the switchboard, provided any such switchboard
section is marked.
(D) Indicating. The building or structure disconnecting
means shall plainly indicate whether it is in the open or
closed position.
225.39 Rating of Disconnect. The feeder or branch-circuit
disconnecting means shall have a rating of not less than the
calculated load to be supplied, determined in accordance
with Parts I and II of Article 220 for branch circuits, Part III
or IV of Article 220 for feeders, or Part V of Article 220 for
farm loads. Where the branch circuit or feeder disconnecting
means consists of more than one switch or circuit
breaker, as permitted by 225.33, combining the ratings of
all the switches or circuit breakers for determining the rating
of the disconnecting means shall be permitted. In no
case shall the rating be lower than specified in 225.39(A),
(B), (C), or (D).
(A) One-Circuit Installation. For installations to supply
only limited loads of a single branch circuit, the branch
circuit disconnecting means shall have a rating of not less
than 15 amperes.
(B) Two-Circuit Installations. For installations consisting
of not more than two 2-wire branch circuits, the feeder or
branch-circuit disconnecting means shall have a rating of
not less than 30 amperes.
(C) One-Family Dwelling. For a one-family dwelling, the
feeder disconnecting means shall have a rating of not less
than 100 amperes, 3-wire.
(D) All Others. For all other installations, the feeder or
not less than 60 amperes.
225.40 Access to Overcurrent Protective Devices. Where
a feeder overcurrent device is not readily accessible, branchcircuit
overcurrent devices shall be installed on the load side,
shall be mounted in a readily accessible location, and shall be
of a lower ampere rating than the feeder overcurrent device.
