You will also need a good trencher!![]()
You also need to keep neutrals and ground wires seperated. You can use a main breaker panel or install a disco.
If you ran a four wire I would isolate neutrals and grounds.
If you ran a three wire with no other metallic paths back to main building I would treat the same as a service and NOT isolate grounds and neutrals. Also use grounding electrodes at remote building.
The latter part of malty's post was permitted under the 2005 and earlier NEC editions but not under the 2008 NEC.
