outbuilding
heat miser
New User
NY
squid hunter
I have a single 20 amp circuit feeding an outbuilding, for a handful of receptacles, switched ceiling fan and one light. I realize a switch would have been sufficient for disconnect means but I installed a 60 amp disconnect in case I decide in the future to add a 2nd circuit. The disconnect enclosure: buss for the ground and no buss for the neutral. Obviously use just one side of the breaker for hot. Q: on the neutral, is there any issue in the code for splicing in the enclosure or should the neutral be run without splicing, to the 1st receptacle or splice box?
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
