Outdoor Boxes (Light and Outlet)
New construction of metal-clad cabin. I'm installing lights at both back door and front decks. Outlets at front and back of home.
From what I have deduced, standard boxes are okay as long as the outlets are GFCI protected with an "in-use" protective cover and lights are outdoor lights.
That doesn't quite feel right to me from a safety perspective. Do the boxes not need to be watertight or covered by a vapour barrier of some type?
If I were to install a standard box, I would need a box extension because the siding of my home is about 3/4 thick after spacers and metal are considered. Putting a standard box in requires making the hole excessively large due to the mounting brackets, etc. and would thus leave gaps that wouldn't be covered by the standard in-use covers. I really expected to find water tight boxes sold at the local big-box store, but i have not seen them.
I think I'm missing something... and it's probably obvious.
What is the proper solution here?
Norm
I am closing this thread in accordance with forum rules. This forum is intended to assist electricians, electrical contractors, inspectors, engineers, and other members of the electrical profession with their job related duties. If you are not an electrician, we are not permitted to help you perform your own electrical troubleshooting, installation, or maintenance work.
