mshields
- Boston, MA
What governs the size of a concrete pad relevant to the equipment sitting on it? e.g. If you have a pad mounted transformer that's 10 x 10 (let's pretend they come perfectly square), is there any code mandated limitation on how much larger the pad should be. i.e. you could certainly make the pad 10'-6" by 10'-6", but is there anything to prevent you from making it 11 by 11 or 12 by 12? Also does the code have anything to say on the height above grade of the pad?
