I'm looking for code requirements that allow or prohibit the following in the State of Ohio:
Assume all required clearances are met. The generator is 500KW and sits on a belly tank that sits on grade (on a cement pad, of course.). This is a level 1 system as defined by NFPA 110.
- Can the generator be located in the same ?yard? as mechanical equipment (e.g. cooling towers)?
- Can the generator be located adjacent to the owner's 12.47kV-480V primary outdoor pad mounted transformer?
