CAEmerson
- Seattle, WA
- Retired
For a new outdoor safety disconnect, 480 volts three-phase, (City of Seattle) I've made a label with acceptable information (voltage, source of power, use of power etc.) to the inspector. However I have afixed it to the equipment using a waterproof packing slip bag with full sticky on the back. Any attempt to remove the label is not easily done because the attachment is permanent. Also, since it's been known to rain in Seattle from time to time, it has already been tested by the elements.
However my inspector wants me to follow the NEC rule as noted in 110. 21, but without describing what type of labeling would actually be acceptable. He did note that a phenolic name plate would be acceptable.
I have searched the web and have yet to find any description of what constitutes an acceptable labeling for outdoor use.
This is a problem that has been solved thousands upon thousands of times, so I'm asking the forum for various cost effective suggestions.
