got a h.o. called having problem with outdoor light tripping gfci.
looked for other loads conected off of the circuit found none
looked at circuit were ran out of garage j box had pinched wire
with copper showing but alot of silicone were pinched
fixed that but went ahead looked at rest of installation
everything looked fine
wires tested fine
so thought maybe the pinched spot couldve been culprit
change gfci (homeowner said he reset it a'' jillion" times!
calls a week later gfci still trippin .any ideas think ballast may be on brink??
light :500watt halegen
120 volt
no other load on circuit
direct buriel cable
wires tested fine
120 volt
direct buriel cable
