When outdoor sw.gear gets installed and conduits are swept into the gear (located on a conc. Pad) does the conduit usually ?stub? into the gear, or does the pvc conduit typically get installaed flush with the top of the pad? Also what would you typically see as the minimum cl spacing for conduits? We are looking to utilize however in order to fit in the conduit opening in the bottom of the gear with 4?c.?s and the quantity we would have a 5? center to center spacing with only 1? between at the equipment, typically we shoot for 6.5? center to center, just curious from an installation standpoint.
