outdoor generators
Roger-
You are correct,this is my point-you will find that generator manufactures can not or more likley will not make the breakers on the gen sets,readily available,within site,nor have the SUSE,rating.There are ALOT of installations of outdoor generators where the installers will wire to the brk on the gen set without a SUSE disc.means,I beleive this is a common wiring method that continually happens without being inforced to be code compliant.
