Well here is some info on a Hot Springs tub
230 VOLT PERMANENTLY CONNECTED MODELS
?[FONT="] [/FONT]Vista8 (Model SS)? Grandee8 (Model GG) ? Envoy8 (Model KK)
?Vanguard~ (Model VV) ? Sovereign~ (Model II) ? Aria ? (Model AR)
HOT SPRING SPAS MUST BE WIRED IN ACCORDANCE WITH All APPLICABLE LOCAL ELECTRICAL CODES. All ELECTRICAL WORK SHOULD BE DONE BY AN EXPERIENCED, LICENSED ELECTRICIAN. WE RECOMMEND THE USE OF APPROPRIATE ELECTRICAL CONDUIT, FITTINGS, AND WIRE FOR ALL CIRCUITS.
An electrical sub panel containing two GFCI breakers is included with each 230 volt spa. We recommend that this subpanel be used to supply power and protect the spa.
This subpanel requires a 50 amp, single phase, 230 volt, four wire service (two line, one neutral, one ground). The grounding conductor must be at least the same gauge as the line conductors, but not less than #10 AWG. A minimum #10 AWG solid copper bond wire is also required.
Mount the subpanel in the vicinity of the spa, but not closer than five feet away, in accordance with all local codes. (N.E.C. 680-38 to 41-A-3)
