SpringHill
I am replacing an outdoor light post at the street with a new lantern mounted on an aluminum post. The new post requires an equipment ground.
The existing circuit runs from the switch through old armored cable (BX) and joins in a junction box under the eaves to new UF, thence underground approximate 20 feet to the lamp post.
Can I assume that the BX (it contains the small ground wire) provides an acceptable ground for this outdoor installation? If not,would a separate ground rod at the junction box properly ground the circuit?
