mgookin
- Fort Myers, FL
- Retired inspector, plans examiner & building official
This is for installation of a GPS enabled relay controller which effectively is a timer which never requires programming. The optimal installation is with a clear view of the horizon, although it does work inside an attic with wood trusses, plywood roof and asphalt shingles. It does not work under a steel pan roof atop bar joists. There are two valid reasons to have a bypass. First is to service bulbs & ballasts which may be on the circuit and second is to turn on the lights on Christmas day, for a parade, etc. This switch can be down at grade, in an electric room, etc. while the control is mounted up high. One existing customer has to send guys up ladders every time they have an event just to put a cup over the existing photocontrols. This bypass installed in his electric room will make him happy.
This creates a parallel condition when both the switch and the control are closed.
Any objections?
Thanks in advance.
Any objections?
Thanks in advance.
