solo618
- Orange County, N.Y.
Hey guys! I want to put lamp posts around my yard,7 actually with each post able to hold 3 lamps at 100 watts max, so i guess 300 watts per posts. okay so i figuered i'd put three posts on one 15amp ckt and 4 on another because i figured 80% of the 15 amp ckt is 1440 watts. The problem is the last post will be about 360ft from the panel. I'm worried about the voltage drop. At first thought i was thinking i should run #8 or would #10 be sufficient.
